Hi All,
How to select instances in the active cellview
by using Ruby ?
For example, I would like to select all instances
whose cellname is "BGAP_SMALL_AMP".
How to do that by using Ruby script ?
The "selection" inside the view is not something you can control through Ruby currently. You can read and clear the selection but not select certain objects.
If you plan to manipulate those instances, Ruby is an option. In that case you could traverse the layout looking for those instances and code some manipulations inside your script.
Another way to apply manipulations (for example, delete or replace such instances) without using Ruby scripts is the "Search and Replace" feature. See http://klayout.de/doc/manual/search_replace.html for details about that.
Thanks for your reply .
I mean by "select", just like pressing
the left mouse button, then drag a rectangle
around the instance, then the instance will be
highlighted. Because if I want to find the location
of all the instances "BGAP_SMALL_AMP" in the cellview,
it is difficult to select or search them one by one .
Hi Marben,
What do you mean by "select"?
Best Regards,
Marben
Hi Marben,
well, that is the selection that is not accessible through Ruby - maybe it will in future versions, but I can't promise.
You can manipulate objects though. But that depends on what you want to do with the selection.
