Alpha/numeric for Kayout
edited February 2010 in KLayout Support
Is there a Alpha/numeric function in Klayout?
  • edited 12:59PM
    what exactly do you mean with that function? A function to create text fields?
  • edited 12:59PM
    Can I add text or numbers in layout, so I do not have to manually draw the letters or numbers.
  • edited 12:59PM
    Hi sedborg,
    such a function is on my todo list since some time now. However, I felt that there are a couple of constraints that complicate the choice of the character pattern (angle constraints, design rules, grids and similar).
    So far, my recommendation is to create a set of cells containing one letter each and placing the cells to create a text field. I agree that is not as convenient as having a built-in function but is the most flexible way and offers the maximum flexibility. You can put the character cells in a separate GDS file and use copy & paste to place the cells into your target layout.
