Python script with PluginFactory
edited December 2017 in Python scripting
Dear experts
I am trying to reproduce the Ruby script example for PluginFactory from here https://www.klayout.de/doc/code/class_PluginFactory.html
class PluginTestFactory < RBA::PluginFactory
  # Constructor
  def initialize
    # registers the new plugin class at position 100000 (at the end), with name
    # "my_plugin_test" and title "My plugin test"
    register(100000, "my_plugin_test", "My plugin test")
  # Create a new plugin instance of the custom type
  def create_plugin(manager, main_window, view)
    return PluginTest.new
# The plugin class
class PluginTest < RBA::Plugin
  def mouse_moved_event(p, buttons, prio)
    if prio
      # Set the cursor to cross if our plugin is active.
      set_cursor(RBA::Cursor::Cross)
    # Returning false indicates that we don't want to consume the event.
    # This way for example the cursor position tracker still works.
    false
  def mouse_click_event(p, buttons, prio)
    if prio
      puts "mouse button clicked."
      # This indicates we want to consume the event and others don't receive the mouse click
      # with prio = false.
      return true
    # don't consume the event if we are not active.
    false
# Instantiate the new plugin factory.
PluginTestFactory.new
This is what I have so far:
class PluginTestFactory(pya.PluginFactory):
    def __init__(self):
        super().__init__()
        self.register(100000, 'my_plugin_test', 'My plugin test')
        return PluginTest()
class PluginTest(pya.Plugin):
    def __init__(self):
        super().__init__()
    def mouse_moved_event(self, p, buttons, prio):
        if prio:
            self.set_cursor(pya.Cursor.Cross)
        return False
        if prio:
            print('this output goes in the terminal')
            return True
        return False
PluginTestFactory()
However, if I
  1. open a gds file with two boxes (this one, specifically: https://www.dropbox.com/s/j11zhnjxszta3iq/foo_static.GDS?dl=0)
  2. Run the script from the Macro Development dialog in debug mode with Shift+F5
I get the error
std:bad_alloc in PluginFactory.register (Class RuntimeError)
Press 'Ok' to continue and 'Cancel' to stop in the debugger
On clicking 'Ok' I get the following:
std::bad_alloc in PluginFactory.register
C:/Users/MCHels/KLayout/pymacros/qt_designer_python_1.lym:4
C:/Users/MCHels/KLayout/pymacros/qt_designer_python_1.lym:24
So, did I mess up the Ruby to Python conversion or is something else up?
Also, thanks to Matthias for creating this awesome piece of software!
    thanks for reporting this issue.
    I can reproduce the problem. Apparently it's a reference count issue with the object returned by create_plugin. With Ruby there is no such issue because Ruby does memory management differently.
    A workaround is to hold a reference to the new object
        plugins = []
        def __init__(self):
            super(PluginTestFactory, self).__init__()
            p = PluginTest()
            PluginTestFactory.plugins.append(p)
            return p
    However, this creates a memory leak because those objects are never deleted.
    I'll take a look into this.
    Hi Matthias
    Thank you for getting back to me on this. You're awesome.
    Morten
