Merge multiple .gds files to one parent cell?
edited November 2015 in Ruby Scripting
I am trying to merge multiple GDS files into one parent cell with given XY offset. I am having trouble with my "cell.insert" i get an error "No overload with matching arguments in CellInstArray::initialize" . Any help would be greatly appreciated.
Keil
<code>
module MyMacro
include RBA
ly = RBA::Layout::new
ly.read("firstFile.gds")
ly.read("secondFile.gds")
ly.read("thirdFile.gds")
X = [0,100,1000]
Y = [0,100,1000]
i = 0
# create new cell TOP
cell_index = ly.add_cell("TOP")
cell = ly.cell(cell_index)
#Get top cell of file
top_cell_name = ""
ly.top_cells.each { |curCell|
p "topcell: " + curCell.name + " and index:" + curCell.cell_index.to_s + " " + cell.name
if top_cell_name == "TOP"
next
else
#Add top cell to main layout
x = (0.5 + X[i] / ly.dbu).to_i
y = (0.5 + Y[i] / ly.dbu).to_i
p "x:" + x.to_s + " y:" + y.to_s
cell.insert(RBA::CellInstArray::new(ly.cell(curCell.cell_index), RBA::Trans::new(RBA::Point::new(x, y))))
ly.delete_cell_rec(cur_cell)
i = i + 1
ly.write("my_layout.gds")
</code>
  • edited November 2015
    Hi Keil,
    The message says there are multiple versions and none is accepting the arguments that you provide. It refers to "RBA::CellInstArray::new" (it says "initialize" instead of "new" - that's Ruby slang for the constructor).
    The version you require is the one that accepts a cell index(!) and a transformation. You converted to the index to a cell reference using ly.cell(..) already and since the constructor takes a cell index, it does not accept these arguments.
    The right way is:
    cell.insert(RBA::CellInstArray::new(curCell.cell_index, RBA::Trans::new(RBA::Point::new(x, y))))
    Thank you sir. That fixed it. How do you post code like you do? I tried <code> </code> like some other forums but that did not work.
    Thanks again,
    Keil
    This forum uses Markdown. Precede each line of code with at least four spaces.
    Thanks guys. This is what i ended up using.
     module MyMacro
     #klayout_app.exe -b -r mergeFiles.lym -rd files=firstFile.gds,seconldFile.gds,thirdFile.gds -rd outputFile=my_layout4.gds     -rd X_cord=0,30000,60000 -rd Y_cord=0,0,0
    #Each file should have a unique top cell.
    include RBA
    #read in each file
    $files.split(",").each do |file|
         ly.read(file)
    X = $X_cord.split(",")
    Y = $Y_cord.split(",")
    i = 0
          #skip TOP so we dont add it to self
          if curCell.name == "TOP"
            next
          else
            x = (0.5 + X[i].to_i / ly.dbu).to_i
            y = (0.5 + Y[i].to_i / ly.dbu).to_i
            i = i + 1
      ly.write($outputFile)
    I tried Keil's code with Mathias's correction, but ran into a different problem.
    Line:
    Error:
    "Internal error: /usr/src/packages/BUILD/klayout-0.24.9/src/dbLayout.cc:1289 topological_sort () was not true in Layout::write (Class RuntimeError)"
    Can you give me some suggestion?
    Hai
  • edited November 2017
    Hi Hai,
    this exception is thrown when you managed to create a recursive hierarchy.
    I assume there already is a TOP cell in your layout. In this case, the new top cell created will be called "TOP$1", not "TOP", and the code fails.
    Here is a somewhat enhanced version of the above code (note a few enhancements)
    module MyMacro
      # Read in each file
        ly.read(file)
      i = 0
      # Create new cell TOP (or similar unique name)
      # Get top cells of the file
      ly.top_cells.each do |curCell|
        # Skip TOP so we dont add it to self
        if curCell.cell_index != cell.cell_index
          # Add top cell to main layout
          x = (0.5 + X[i].to_f / ly.dbu).to_i
          y = (0.5 + Y[i].to_f / ly.dbu).to_i
          i += 1
    Please note that the "read multiple layout into one object" bears the risk of cell collisions: if two cells of different layout files carry the same name, their contents will be merged. This will usually spoil the layout.
    I tried to use the macro file oasis files, but KLayout return me the message :
    Caught the following exception :
    Unable to open file: MYFILE.oas (errno=2) in Layout::read (Class RuntimeError)
    But if I open MYFILE.oas interactively, it works fine.
    Where is the limit to open oasis file ?
    Thanks, BRgds,
    I solved my problem by adding the path (with \\ instead of \).
    Right ... common issue on Windows :-)
    You can also use forward slashes. Works too and avoids the backslash escaping issue.
