Hello Matthias,
Do you know if it is possible to check for a polygon with a null area?
I mean, one of its dimensions being zero?
I tried the function layer.with_area(0), but the null-area polygon is not recognized even by the functions layer.edges or layer.output.
Although I can see this polygon as two collapsed parallel edges.
Uiara
Here is a way I use it:
I think that such polygons get removed in merge semantics. But they are kept in "raw" mode. So I think this is how you can check this:
