Hi
I am writing a python script but can not figure out how to do debug the script. I can insert print statements in the script but it becomes time consuming and not very effective. Is there a way to run the "pdb" like thing to step through the python script?
enuinc
If you are using the built in IDE (Press F5 to get it), then there are two toolbar buttons with tiny short or long green arrows -- to step into or over blocks. Just like pdb. You can also press F10 or F11.
Hi enuinc,
Basically for your kind of application, the Python API should be available as a plain Python module. That's not my main scope and raises some license questions, so I have not provided such a module yet.
As of now, you can use the following trick:
For normal operation, use
for debugging, use
