Hi I am having trouble adding a new cell to an existing open GDS file.
Here is my code:
module MyMacro
include RBA
main_window = RBA::Application::instance.main_window
layout = RBA::CellView::active.layout
layout_view = main_window.current_view
layout.dbu = 0.001
wg0 = layout.insert_layer(RBA::LayerInfo::new(1, 0))
cname = "CELLNAME"
cell = layout.create_cell("#{cname}")
TEXT OF CODE
layout_view.select_cell(cell.cell_index, 0)
layout_view.zoom_fit
The code creates a blank cell without any shapes in the existing GDS. If replace the "layout" line with:
layout = main_window.create_layout(1).layout
a new cell in a new layout is created with the shapes I need.
as I don't see the actual code, it's hard to tell what's wrong. But maybe the problem happens because you create a new layer. New layers aren't visible by default. Try
at the end of the script to make them visible.
Thanks for the pointer Matthias. Based on your feedback I realized that the layer already existed within the existing GDS and hence I changed the layer definition from:
to
Now the code works as expected. Thanks!!
