"Trans::new" "no implicit conversion"
Trying to run .rb script:
trans = Trans::new(Trans::R270, false, 0, 0)
returns error "no implicit conversion for RBA::Trans into Integer (Class TyperError)"
Klayout version = 0.25.5
Ruby interpreter 2.4.0-p0 (x64-mingw32)
Has anyone come across this error before?
  • The rotation is expressed in units of 90 degrees (see doc), so in Python this works:
    trans = klayout.db.Trans(270, False, 0, 0)
    which means that in Ruby this should work:
    trans = Trans::new(270, false, 0, 0)
    Cheers, Erwin
  • edited October 2018
    Hi Erwin,
    thanks for answering, and I'm a bit sorry I have to correct you ...
    By "in units of 90 degree" I meant that 0 = 0, 1 = 90, 2 = 180 and 3 = 270. Maybe the description is kind of misleading.
    So 270 degree are actually:
    pya.Trans(3, False, 0, 0)
    It gets a bit more confusing when you switch to complex transformations with an arbitrary angle. For those it's really degree, so the equivalent of 270 degree as integer-to-integer complex transformations is:
    pya.ICplxTrans(1.0, 270, False, 0, 0)
    The error above actually happens only because Trans.R270 already is a Trans object representing a 270 degree rotation. So the answer simply is:
    trans = pya.Trans.R270
    or in Ruby:
    trans = RBA::Trans::R270
  • Hi Matthias, thanks for the correction. Best regards, Erwin
