Hi, What would be the easiest way to open klayout and directly display a specific subcell from command line ? Many thanks for you help.
you can achieve this through a script:
Save this to "show.rb":
RBA::Application::instance.main_window.load_layout($layout, 1) cv = RBA::CellView::active cv.cell = cv.layout.cell($cell)
And run KLayout this way:
klayout -rm show.rb -rd layout=path_to_layout -rd cell=cell_name
There currently is no option on the command line to specify the cell name to show initially. But that's a nice suggestion.
Thank you for your answer... but unfortunately I get an error:
Cannot call non-const method on a const reference in CellView::cell= show.rb:3:in cell=' show.rb:3:in
cell=' show.rb:3:in
I use KLayout 0.24.7
on OSX 10.11.6
Philippe
I tried on RHEL6 and it works fine. It may comes from a compatibility issue with the native ruby version. I will check it.
that's because 0.24.7 is a bit outdated. The script above requires a 0.25.x version.
A compatible version of the script is:
RBA::Application::instance.main_window.load_layout($layout, 1) lv = RBA::LayoutView::current cv = RBA::CellView::active lv.select_cell(cv.layout.cell($cell).cell_index, cv.index)
show.rb:3:in
cell=' show.rb:3:in
I use
KLayout 0.24.7
on
OSX 10.11.6
Philippe
