I have Klayout installed on two computers. The version number is the same and for most part, I have not made major changes to the "Setup". However, in one installation, I am able to select shapes at lower levels of hierarchy without descending the hierarchy (i.e. from the top level), while in the other installation, I can only select the cell at the top level and I have to actually descend into the cell to make changes to the same shape.
I am sure there is some "setting" difference between the two and for the life of me, I cannot figure what that setting difference is and what switches in the "File -> Setup" I need to toggle to allow for the shape selection to occur only when descending into the cell.
Please could someone help! It would be much appreciated. I hope my description of the problem above makes sense.
Vikas
Please ignore this request. I figured out that I need to select the "View" -> "Select Top Level Objects".
Vikas
