I have developed a Ruby script to import an IPC-D-356 net-list file to add drill hole locations & net-name labels to a layout created by reading Gerber files via File>Import >Gerber PCB>New Project - Free Layer Mapping
This resolves the issue of attempting to read the 'Drill Files' without any way of setting the data format
Adds the net names to match the source PCB design
Is there any way of calling input() and connect() to create the 'technology' on the fly instead of having to pre-define the technology before the input process?
@davidnhutch Thanks - but ideally there was a kind of standard for drill files without need for setting the data format. Any idea?
You can actually code the netlist generation directly without a technology. The key to this feature is the "LayoutToNetlist" class. Here is some sample code taken from the tests. I hope it's comprehensible. It uses two metal layers + one via and reads labels from both metal layers for net names:
Matthias,
Thanks for the sample code, I implemented it over the weekend,
but found the tool became unstable when attempting to use Tools>Net Browser after running it
I reverted back to the original code & will use the technology files for the connectivity
My client/customer is very pleased with the functionality provided with KLayout,
this will allow them to no longer require an expensive Siemens EDA/Mentor Graphics/Valor NPI license...
@davidnhutch What do you mean by "unstable"? I'm a bit worried - that should not happen.
What's the version and OS you're using? And maybe you can share some sample code which allows reproducing the problem?
I'm running Windows 8.1 Version 6.3 (Build 9600) 64bit on a laptop with i7-4710HQ cpu + 32Gb ram
Can I upload and/or send you a zip file with the sample data & script?
I sent an email yesterday containing a zip file with the gerber files, ipc netlist, script & process flow to allow you to hopefully duplicate the issue...
@DavidJHutchins Thanks for the test case! See my reply and here: https://github.com/KLayout/klayout/pull/852
I just sent you an email with new test-case data, I can not get the connectivity generated correctly using
the ruby code included in the email & I do not know how to debug the data saved in the .l2n file
I corrected my code per your feedback & the connectivity is now correct
Thanks for your assistance...
