Pcell position change
I would like to converted paths (routing) to round_path cells and set radius for all selected cells.
I see an issue when there is more than one cell selected. In the Properties window using next or previous buttons the cells position changes. I see the same problem with the position, when I want to set the radius for all selected cells. I checked also round_polygon conversion and there is the same problem.
Lidia
