QAbstractTableModel does not draw checkbox for checkable items
I am creating table model for my pya based gui and I was able to insert checkbox as widget while using QTableWidget, but after switching to QTableView I don't see checkbox, however, I developed similar application using raw PyQt and checkbox was there.
I am trying to put it into first column and here is my model:
class DRCTableModel(pya.QAbstractTableModel):
def data(self, index, role=pya.Qt_ItemDataRole.DisplayRole):
    if role == pya.Qt_ItemDataRole.DisplayRole.to_i():
        if index.column() == 0:
            value = self.rules[index.row()].rule
        elif index.column() == 1:
            value = self.rules[index.row()].value
        elif index.column() == 2:
            if self.rules[index.row()].status != RuleStatus.UNKNOWN:
                value = self.rules[index.row()].status.name
            else:
                value = ""
        elif index.column() == 3:
            value = self.rules[index.row()].category
        elif index.column() == 4:
            value = self.rules[index.row()].description
        else:
            value = ""
        return value
    elif role == pya.Qt_ItemDataRole.CheckStateRole.to_i() and index.column() == 0:
        return pya.Qt_CheckState.Checked if self.rules[index.row()].is_checked else pya.Qt_CheckState.Unchecked
    elif role == pya.Qt_ItemDataRole.BackgroundColorRole.to_i():
        if index.column() == 2 and self.rules[index.row()].status == RuleStatus.PASS:
            bgColor = pya.QColor(188, 247, 204)
        elif index.column() == 2 and self.rules[index.row()].status == RuleStatus.FAIL:
            bgColor = pya.QColor(255, 187, 181)
        else:
            bgColor = pya.QColor(pya.Qt.white)
        return bgColor
    else:
        return pya.QVariant()
def flags(self, index):
    fl = pya.QAbstractTableModel.flags(self, index)
        fl |= pya.Qt_ItemFlag.ItemIsEditable | pya.Qt_ItemFlag.ItemIsUserCheckable
    return fl
def setData(self, index, value, role=pya.Qt_ItemDataRole.EditRole):
    if not index.isValid():
        return False
    if role == pya.Qt_ItemDataRole.CheckStateRole.to_i():
        self.rules[index.row()].is_checked = value
        return True
    return False
I presented only those methods that important for checkbox column functionality.
Do I need actually to implement my own delegate? Or checkable item functionality does exists in pya?
thank you
  • Hi @EugeneZelenko, thanks for the comment. I am not sure that understand it completely, but it looks like you are referring to changing check state of particular item in your QTreeWidget, am I right?
    The point is that this is widget based way and it works for me as well (for QTableWidget) but I am trying switching to model-view architecture and check state in this way can be controlled through model directly. As I said, with raw Qt or PyQt I know how to do that but here checkbox is not plotting. Please, correct me if I misinterpreted your message.
    Custom editing elements can be handled through user's delegate class, but for checking items it was always possible to use standard delegate.
  • @alexlpn I cannot debug or reproduce that isuee with partial code. Could you paste a full sample that allows me to reproduce the problem?
    The reason may be manifold. I'm not using the Qt classes to an extent I have much experience with that myself.
    A note of caution: the Qt bindings do not have the quality of PyQt, but I could not use PyQt. The reason is that PyQt is build atop of Python while in KLayout, Python sits atop of the application. That is a difference. Plus there was not PyQt equivalent for Ruby. So KLayout's Qt binding is supposed to provide the necessary API for utility UIs, but C++ to Python transition is tricky and I cannot give warranty that all functionality is properly implemented. The Qt API is simply too huge to give it a thorough testing.
    I'd like to debug the issue, but please do not ask me to create a functional sample myself.
  • Hi @Matthias , here I tried to compile small example (actually two).
    This one is raw PyQt5 based:
    from PyQt5.QtCore import QAbstractTableModel, QModelIndex, Qt, QVariant
    from PyQt5.QtWidgets import QApplication, QMainWindow, QTableView
    from dataclasses import dataclass, fields
    from typing import List
    @dataclass
    class Item:
        value: float
        is_checked: bool
    class Model(QAbstractTableModel):
        def __init__(self):
            super().__init__()
            self.items = []
        def setItems(self, items: List[Item]):
            self.items = items
            self.layoutChanged.emit()
        def setAllItemsSelected(self, selected: bool = True):
            for r in self.items:
                r.is_checked = selected
        def rowCount(self, parent=QModelIndex()):
            return len(self.items)
        def columnCount(self, parent=QModelIndex()):
            return len(fields(Item)) - 1
        def data(self, index, role=Qt.DisplayRole):
            if role == Qt.DisplayRole:
                    value = self.items[index.row()].name
                    value = self.items[index.row()].value
                else:
                    value = ""
                return value
            elif role == Qt.CheckStateRole and index.column() == 0:
                return Qt.Checked if self.items[index.row()].is_checked else Qt.Unchecked
            else:
                return QVariant()
        def headerData(self, section, orientation, role=Qt.DisplayRole):
            if role == Qt.DisplayRole and orientation == Qt.Horizontal:
                if section == 0:
                    value = "Name"
                elif section == 1:
                    value = "Value"
                else:
                    value = ""
                return value
            elif role == Qt.DisplayRole and orientation == Qt.Vertical:
                return section + 1
            fl = QAbstractTableModel.flags(self, index)
                fl |= Qt.ItemIsEditable | Qt.ItemIsUserCheckable
            return fl
    class MainWindow(QMainWindow):
        def __init__(self, parent=None):
            super().__init__()
            table = QTableView(self)
            model = Model()
            table.setModel(model)
            self.setCentralWidget(table)
            items = [
                Item("Item 1", 10.0, False),
                Item("Item 2", 20.0, False),
                Item("Item 3", 30.0, True),
                Item("Item 4", 40.0, True),
                Item("Item 5", 50.0, True),
            model.setItems(items)
    if __name__ == "__main__":
        app = QApplication([])
        wnd = MainWindow()
        wnd.show()
        app.exec()
    This one is pya based (the difference is in Qt.CheckStateRole -> Qt.CheckStateRole.to_i() and similar roles :
    from pya import QAbstractTableModel, QModelIndex, Qt, QVariant
    from pya import QMainWindow, QTableView
    @dataclass
    class Item:
        value: float
        is_checked: bool
        def __init__(self):
            super().__init__()
            self.items = []
            self.items = items
            self.emit_layoutChanged()
            if role == Qt.DisplayRole.to_i():
                else:
                    value = ""
                return value
            elif role == Qt.CheckStateRole.to_i() and index.column() == 0:
            else:
                return QVariant()
            if role == Qt.DisplayRole.to_i() and orientation == Qt.Horizontal:
                if section == 0:
                    value = "Name"
                elif section == 1:
                    value = "Value"
                else:
                    value = ""
                return value
            elif role == Qt.DisplayRole.to_i() and orientation == Qt.Vertical:
                return section + 1
            return fl
            super().__init__()
            self.table = QTableView(self)
            self.model = Model()
            self.table.setModel(self.model)
            self.setCentralWidget(self.table)
            items = [
            self.model.setItems(items)
        wnd = MainWindow()
        wnd.show()
    Here are the plots of what gives PyQt and pya in comparison:
    Those checkboxes I am talking about. Usually when I am flagging item as Qt.ItemIsUserCheckable this delegate will be plotted automatically.
    I hope this highlights the issue.
  • edited April 2022
    Thanks, a lot for that nice test case.
    I could debug the problem and fix it by using
                return Qt.Checked.to_i() if self.items[index.row()].is_checked else Qt.Unchecked.to_i()
    (note the to_i() in the return statement).
    Here is my explanation: KLayout treats enums as typed objects. So if you have Qt.CheckStateRole it is actually a constant of type Qt::ItemDataRole.
    That usually works nicely, but for the QAbstractItemModel, for some reason the role is declared as "int" in C++. Hence for the comparison you need to convert to int with to_i. Maybe that can be simplified if I implement some "enum == int" compare. Until then you'll need to_i.
    The same thing happens on the return side. The QVariant binding does not support "enum type to int" automatic conversion, but the C++ API requires an integer value. So again, you'll need to convert to int again. Maybe it's also possible to rectify that so eventually code is more compatible with PyQt5. Right now, I suggest the "to_i" workaround.
  • I have issue a PR which should enable enum-to-int conversion in both directions (https://github.com/KLayout/klayout/pull/1055). This should remove the need for adding to_i. It's a too deep change to go into a minor release, but I'll include it in the next major one.
  • Matthias, this is great, thanks a lot!
