Hi !
No problem here, this is more like a how-to.
In order to build Klayout on ubuntu 10.10 (brand new), I had to install those packages via synaptic package manager :
- gcc and Qt as said in http://www.klayout.de/build.html
- g++
- zlib1g-dev
Perhaps somebody can add this info to the "dowload and build" page ?
Thanks for this great tool.
Ghis
Hi Ghis,
I have updated the build information accordingly. Thank you for that hint.
http://blog.peterscholtens.net/?p=210
Maybe the file can be hosted on this site too?
Peter Scholtens
thanks a lot for the package.
Maybe you can send me a short instruction how you did it (i.e. to the mail listed on the contacts page), so I can provide that package myself for the next releases.
Thanks and best regards,
After re-reading my blog, describing how it did it, I wonder what's unclear to you.
I studied how the ar command works (using a similar, but now removed, blog elsewhere):
http://radagast.bglug.ca/linux/anatomy_of_a_deb_file.html
Thereafter verified the need for the minimum amount of files to create a working package:
http://www.debian.org/doc/debian-policy/index.html#contents
Last but least, checked it with the lintian package, see remaining warnings in my blogpost.
By the way, is there a public repository (subversion, git) for klayout running, so I can download the latest (even unstable) version? See e.g. my own project http://sourceforge.net/projects/casimiro/ (code->SVN)
Greetings,
Peter Scholtens
sorry, I should have read the blog :-)
It's actually very nice. I don't think there is anything unclear.
To simplify the installation for Linux Debian/Ubuntu/Mint users, I've compiled a more recent version (0.21.18) of klayout as Debian packages. You can copy (or refer to) them:
http://scholtnp.home.xs4all.nl/files/klayout_0.21.18-1_i386.deb
http://scholtnp.home.xs4all.nl/files/klayout_0.21.18-1_amd64.deb
Peter Scholtens
Hi Peter,
thanks a lot. I will provide these packages on the web site.
Just a feedback :
After a few months I come back to KLayout with even more pleasure : the installer for Ubuntu 12.04 64bits of version 0.21.19 available at the dowload page works perfectly !
Since it works well, maybe the link to the current installer could be added in the first list ("Download current version") of the download page ?
Right now it is hidden in the "all dowloads" list: I almost missed it.
Thanks a lot Matthias and Peter !
Hallo,
I simply don't have the resources currently to provide ready-to-install builds for Linux platforms. And for MacOS I am lacking the hardware.
I tried to set up a build on OpenSuse's public build service but I stopped that activity because too much was missing on their installations.
I've packaged the latest version also, see the links:
http://scholtnp.home.xs4all.nl/files/klayout_0.22.1-1_i386.deb
http://scholtnp.home.xs4all.nl/files/klayout_0.22.1-1_amd64.deb
It seems the option -v either crashes (64-bit) or hangs (32-bit) in Ubuntu Linux. Possible the exit procedure is not correct?
Peter Scholtens
Hi Peter,
thanks for the packages. I'll put then on the server right now.
You're right, -v is crashing currently. It's a known issue and I'll fix that in the next release.
Thanks, Peter and best regards,
