thanks for your suggestion. What I am trying to do is to transmit images from another process to KLayout via Shared Memory. I am asking the question, because I haven't found a method of the Image Class to read the image data from a byte stream, while with QImage, one can do such a thing. So I was wondering if there was a way to turn a QImage into an Image (of the Image Class), because the cell view's insert_image method only takes an instance of the Image Class as an input, but not a QImage.
HI TTR572
Assuming your are trying to save a QImage data into a image file, you can simply use the save function.
If you like to show the image in you widget, you can use QLabel widget to hold thoes Pixels, and add the QLabel into you widget.
Hi RawrRanger,
Kind Regards
Thomas
Hi @TTR572,
No, right now there is only the temp file approach or using (slow) pixelwise transfer.
If you want creation from a bytestring or QImage or PixelBuffer (without Qt) raise a ticket on GitHub.
thanks for your feedback. I will continue to look for solutions.
Kind Regards
Thomas
I have created this PR to fix your problem: https://github.com/KLayout/klayout/pull/1436
