Subtract one multiple-instanced box from an outer box
edited August 2013 in Ruby Scripting
When I run the following script that I wrote, any boxes on layer2 are subtracted from any overlapping boxes on layer1. However the boxes have to all be in the same cell.
module BoxBoxSubtract
  mw = app.main_window
  lv = mw.current_view
  if lv == nil
    raise "No view selected"
  lv.transaction("Box box subtract")
  begin
    # put code here
    outerboxes=[] #layer 401
    innerboxes=[] #layer 400
    result_cell=[]
    result_layer=[]
      shape = obj.shape
      layout = lv.cellview(obj.cv_index).layout
      lnum = 1 # GDS Layer 1
      dtnum = 0
      outerbox_layer = layout.layer_indices.find do |li|
        info = layout.get_info(li)
        info.layer == lnum && info.datatype == dtnum
      lnum = 2 # GDS Layer 2
      dtnum = 0
      innerbox_layer = layout.layer_indices.find do |li|
      lnum = 3 # GDS Layer 3
      dtnum = 0
      result_layer = layout.layer_indices.find do |li|
      if shape.is_box? && obj.layer == outerbox_layer
        # add it to the array
        outerboxes << obj
        # save a reference to the cell it's on, as this is the one we'll write our result on
        result_cell = layout.cell(obj.cell_index)
      elsif shape.is_box? && obj.layer == innerbox_layer
        innerboxes << obj
    test1 = []
    test2 = []
    outerboxes.each do |b|
      test1 << RBA::Polygon::new(b.shape.box)
    innerboxes.each do |b|
      test2 << RBA::Polygon::new(b.shape.box)
    ep = RBA::EdgeProcessor::new
    outerMinusInner = ep.boolean_p2p( test1 ,  test2 , RBA::EdgeProcessor::ModeANotB, false, false)
    outerMinusInner.each do |p|
      result_cell.shapes(result_layer).insert(p)
    p 'Done'
    ensure
    lv.commit
Now I need to extend that to operate over multiple cells.
Imagine in the most general case I have three cells: "top", "child1", "child2".
On "child1" there is a large box.
On "child2" there is a small box.
On "top", child1 and child2 are instanced, overlapping each other.
When I instance multiple instances of child2 (multiple small boxes on top of one big box), I want the result to be the big boxes minus ALL the small boxes.
Any ideas how to access those cells? I tried duplicating all small boxes onto result_layer first, then doing the boolean subtraction. (Basically, replace
innerboxes << obj
with
new_shape = obj.shape.dup
result_cell.shapes(innerbox_layer).insert(new_shape)
innerboxes << new_shape
HOWEVER, this only seems to duplicate one box over to result_cell, not all instanced boxes in their relative positions; and besides it is strange -- the duplicated cell does not show up at the same xy location as the original instanced cell! I guess I need to find the xy location of the instanced cells, then duplicate onto result_cell and place them to exactly fall on top of their original instances. But have searched and cannot seem to find a way to get the xy location of the instance!
Hope that is clear. Any ideas? Thanks!
  • edited November -1
    Hi David,
    again, please be patient. I'll need some days to comment on this. Acually I am on vacation and my laptop's battery is running low ... :-)
  • edited September 2013
    Hi David,
    it's basically quite simple - you have to apply the relevant transformations. It's easy if you choose to output the results to the current cell, because then the transformation is readily available through ObjectInstPath#trans as a CplxTrans object. In order to stay within integer coordinates we have to create a ICplxTrans object thereof:
    result_cell = lv.active_cellview.cell
    result_layout = lv.active_cellview.layout
    test1 = []
    test2 = []
      # transform into the current cell's space (use a ICplxTrans object to avoid conversion to floating-point coordinates)
      test1 << b.shape.polygon.transformed_cplx(RBA::ICplxTrans::from_trans(b.trans))
      # see above.
      test2 << b.shape.polygon.transformed_cplx(RBA::ICplxTrans::from_trans(b.trans))
    outerMinusInner = ep.boolean_p2p(test1, test2, RBA::EdgeProcessor::ModeANotB, false, false)
    (BTW: I'd suggest to take the layer search out of the each_object_selected loop. Plus I have used Shape#polygon which is more generic than using Shape#box and creating a polygon from that box).
    The above code does not account for the case of multiple loaded layouts. Basically the two kind of shapes can reside in different layouts then. The corresponding extension is possible but adds a lot of special case handling and additional transformations because of potentially different database units to that code.
    Fantastic, thanks! I didn't understand about this transformation meant before. The code is working and I paste final code below for future reference of anyone reading this. It may not be the most efficient or best code but it works..
      if lv == nil
      begin
        layout = RBA::Application::instance.main_window.current_view.active_cellview.layout
        result_layer=[]
        dtnum = 0
        dtnum = 0
        dtnum = 0
          shape = obj.shape
            outerboxes << obj
            innerboxes << obj
        outer = []
        inner = []
          outer << RBA::Polygon::new(b.shape.box).transformed_cplx(RBA::ICplxTrans::from_trans(b.trans)) #test1 << RBA::Polygon::new(b.shape.box)
          # see above.
          inner << RBA::Polygon::new(b.shape.box).transformed_cplx(RBA::ICplxTrans::from_trans(b.trans)) #b.shape.polygon.transformed_cplx(RBA::ICplxTrans::from_trans(b.trans)) #test2 << b.polygon
        outerMinusInner = ep.boolean_p2p( outer ,  inner , RBA::EdgeProcessor::ModeANotB, false, false)
        p 'Done'
        ensure
        lv.commit
