I've only ever instanced Basic.TEXT PCells, and it's worked fine.
Now I tried to instance some other PCells using the same method, and it's not working...
See the final three lines below for the test cases. Can you please tell me why CIRCLE and ARC (and others) don't seem to work? I observe some black handles on the layout, but nothing on Layer 1 for CIRCLE and ARC.
include RBA
def place_pcell(lib_dot_pcell, cell, params)
lib_str, pcell_str = lib_dot_pcell.split('.')
lib = Library.library_by_name(lib_str)
lib || raise("Unkown lib '#{lib_str}'")
pcell_decl = lib.layout.pcell_declaration(pcell_str)
pcell_decl || raise("Unknown PCell '#{pcell_str}'")
pv = pcell_decl.get_parameters.collect { |p|
params[p.name] || p.default
pcell_var = cell.layout.add_pcell_variant(lib, pcell_decl.id, pv)
trans = Trans.new(Trans::R0, 0, 0)
cell.insert(CellInstArray.new(pcell_var, trans))
##### START OF SCRIPT ###
include RBA
app = Application.instance
mw = app.main_window
lv = mw.current_view
lv || raise("No view selected")
ly = lv.active_cellview.layout
dbu = ly.dbu
cell = lv.active_cellview.cell
layer = LayerInfo.new(1,0)
text_params = { "layer" => layer, "text" => "KLAYOUT RULES", "mag" => 100 }
circ_params = { "layer" => layer, "radius" => 10, "npoints" => 64 }
arc_params = { "layer" => layer, "radius1" => 10, "radius2" => 12, "a1" => 0, "a2" => 90}
place_pcell("Basic.TEXT", cell, text_params) # WORKS
place_pcell("Basic.CIRCLE", cell, circ_params) # DOESN'T WORK
place_pcell("Basic.ARC", cell, arc_params) # DOESN'T WORK
thanks for that nicely prepared testcase.
The solution is quite simple: the true parameters are not "radius" .. but "actual_radius" etc. The working code is:
The background is the following: the PCell's of the BASIC lib are intended to interactive use. They provide "handles" which can be moved with the mouse to adjust parameters. So basically there are two ways to manipulate the parameters: through the parameter page and through the handles. The handles are independent - there is no way currently to tie the handles (which are just points) to the derived parameters such as radius and angles. The PCell solves this problem by keeping three parameter sets: one for the parameters on the parameter page, one for the handles and a (hidden) parameter set for the parameters actually used. So if asked to update itself (upon "coerce"), it will check which parameter set has changed and update the actual parameters. From those parameters it will produce the shapes.
Anyway, that just indicates that there is some magic behind PCells, specifically the Basic primitives. I wonder why people want to instantiate a Circle - it is probably the most difficult way to produce a circle. If you generate layout, then why not directly generate a circle? There is even a Polygon constructor for that purpose (
Polygon#ellipse). Or you code it yourself: http://klayout.de/forum/comments.php?DiscussionID=562.Matthias
Thanks Matthias,
You are right, in this case it's easier to code a circle myself. I was more reporting what I thought was a strange behavior, and unsure of where else (in more complicated scenarios) it would show up.
I see now I was using the wrong parameter. Thanks!
As a side-note, you mention placing a circle PCell is more coding than just drawing a circle itself. However, that need not be the case. I would think it would be really nice to implement something like my "place_pcell" method above, so PCells could be placed with just one line of code. For example if it was a method of the Cell class, to place a pcell inside cell 'cell' you'd just have to write
Perhaps a feature request for the API :-)
Hi David,
since 0.24 there already is a similar function: It is accessible via a
Layoutobject and calledcreate_cellwhich takes the name and a parameter map (see the documentation for more info).By the way, some time ago I had pretty much the same idea/request, and this is where Matthias informed me about
create_cell:http://klayout.de/forum/comments.php?DiscussionID=630&Focus=2844#Comment_2844
I agree that having a method like
place_pcellavailable on theCellclass would be even more convenient. This is probably even possible to add via Ruby, but I haven't tried that yet :-)
