Hello! I have a question regarding DRC.
When running DRC on large & complex layouts, I often run into an issue of hanging/crashing. This seems to be particularly present when there are many instances of waveguide structures and rules such as separation, space, or width are attempting to be checked.
My local machine has 65GB ram & an 8 core processor.
I have these DRC commands (where layer and o_l are defined as layer inputs, value is a number, and rule & description are strings):
o_l.sep(layer, value).output(rule, description)
layer.width(value, angle_limit(45.degree)).output(rule, description)
layer.space(value) .output(rule, description)
And the behavior is that it slows my computer down, consuming all the memory, until KLayout becomes unresponsive for quite a while until eventually crashing. This behavior is also present when I implement tiling.
I am wondering what you suggest doing to be able to successfully run these kinds of DRC rules on layouts such as this with many structures present.
Hi spark_aeon,
To find out what's going on in a DRC script you can use the
profileDRC function. That will provide you with the time spent and memory used for each function call.verbose(true)is also useful in general debugging.It seems you are running out of memory. The
forgetmethod of the layer object could help.Regards,
S
Hi @spark_aeon,
There are too many reasons, so I am not able to give advice without a test case and the full DRC script.
As @srooks10 mentioned, "profile" can help you identifying the resource hogs.
Some hints:
I hardly see the need for using so much memory. Even millions of polygon vertexes should not be an issue, provided the problem is broken down properly.
