you mean a fresh layout? That's "layout.dbu". I think that this will be the DBU of the last layout loaded, if you load multiple layout files into the same layout object.
Basically I wrote the following method in order to load new cell of a gds file into the current layout. So, what you are saying is that the second line of the code "p lyo.layout.dbu" will give me the DBU of the loaded gds file? (just to confirm)
It confuses me a little bit, because the layout I am working on has its own dbu and I do not understand how "layout.dbu" will give me the data-base unit of the loaded gds file, rather than giving the data-base unit of the layout that I am working on, itself.
"read" on an existing layout is rather simple merge - it will read the shapes and cells from the layout file right into your existing one, adding to existing layers and cells if possible.
The database unit will simply be overwritten. If you want to check wether the database unit is different, save it before the "read" and compare against the one after the "read". However this will just tell you that the DBU's were different and it's too late then to correct the differences.
If you need better control, you two layout objects and Cell#copy_tree to copy over the cell trees from the new layout object to your working object.
Hi Hamed,
Thank you,
Hamed
def insert_gds(file_path,gds_name,cell_name,foundry1_to_foundry2,scale,rot_angle,flip,new_x,new_y,lyo)
lyo.layout.read(file_path +gds_name+".gds")
p lyo.layout.dbu
lay = lyo.layout.layer_indices.find do |li|
info = lyo.layout.get_info(li)
info.layer == 90 && info.datatype == 0
lay || raise("The label's layout does not contain layer 90, datatype 0")
lyo.layout.set_info(lay, RBA::LayerInfo::new(101, 0)) # change layer
lyo.topcell.insert(RBA::CellInstArray::new(cell_index,RBA::CplxTrans::new(scale,rot_angle,flip,RBA::DPoint::new((new_x / dbu).round,(new_y / dbu).round))))
Hamed
Hi Hamed,
Cell#copy_tree
to copy over the cell trees from the new layout object to your working object.Matthias
