Hi all,
I'm missing (or at least I didn't find a way) NOT to be able to select an instance - like it is possible e.g. in virtuoso.
I often have the problem, that in a design that consists of many instances/cells I don't want to select some of them when I mark the whole layout. I know that I can show or hide certain cells, but marking across the whole layout makes no difference - they are all selected then.
The idea is, that I want for example flatten maybe 490 of 500 cells and 10 cells not and it is very, very hard to mark (and therefore select) all cells in sum and find and deselect then manually the few cells I don't want have :-(. So the best way for cell activities would be not only to be able to hide/show cells but also to be selective/ not to be selective.
Or is there already way I didn't see/find, yet??
Thanks and very best regards
Dirk
Hi Dirk,
I nearly had the same problem and solved it with a macro. See :
https://klayout.de/forum/discussion/1129/search-and-select-cells-in-a-given-area
BRgds,
Laurent
Hi Dirk,
you can choose what to select in "Edit/Select": there are some tick marks next to the items you can select. If you remove the ticks from "Instances" these do not get selected anymore.
A bit later then expected but nevertheless: Thanks to both of you. I'll check Laurent_c script, hoping that I do understand the content and function.
Best regards
Dirk
