I am using the write function in order to save my layout as a .gds file. However, the output file seems to go into Appdata/Roaming, where the program is installed. Is there a way to write differently?
for example,
end the file with
Layout.write("C:/Desktop/layout.gds")
Thank you very much!
Shoval.
Hi Shoval,
just specify the path. On windows that should be
Layout.write("C:\\Desktop\\layout.gds")
, but forward slashes should work too.Matthias
