Retrieve xy coordinates of selection
I wish to retrieve the actual xy coordinates of a selected shape. On the forum, there are several examples where a recursive search is used (top down) to retrieve the associated transformation. In this case however, this takes too long and I'd like to implement a bottom up approach. Unfortunately, the code only works partially:
lv = pya.LayoutView.current()
s = next(lv.each_object_selected()) # Only the first selected object
tran = search_tran(s.shape.cell)
point = shape.polygon.transformed(tran).point_hull(0)
def search_tran(child_cell):
  cell = child_cell
  tr = []
  while not(cell.is_top()):
    cellinst = next(cell.each_parent_inst()).inst()     # Consider first element
    cell = ly.cell(next(cell.each_parent_cell()))       # go to parent
    tr.append(cellinst.cplx_trans)
  tran = pya.CplxTrans()
  for k in range(len(tr)-1, -1, -1):
    tran = tran*tr[k].invert()
  return tran
The problem is with the line containing cellinst. I'm not sure how to decide which instance to extract that belongs to the shape.
  • I think I found it. The absolute transformation of the selection is already contained in s.trans(). This gives the following code, which is able to extract the name of a selected shape.
    import math
    dbu = ly.dbu
    shape = None
    cell = None
    cv = lv.cellview(s.cv_index)
    shape = s.shape
    if shape:
      tech = pya.NetTracerTechnology()
      tech.connection("31/0", "51/0", "32/0")
      tech.connection("32/0", "52/0", "33/0")
      tech.connection("33/0", "53/0", "34/0")
      tech.connection("34/0", "54/0", "35/0")
      tech.connection("35/0", "55/40", "36/40")
      tech.connection("36/40", "56/40", "37/60")
      tech.connection("31/0", "131/0")    # Labels
      tech.connection("32/0", "132/0")
      tech.connection("33/0", "133/0")
      tech.connection("34/0", "134/0")
      tech.connection("35/0", "135/0")
      tech.connection("36/40", "136/0")
      tech.connection("37/60", "137/0")
      point = shape.polygon.transformed(s.trans()).point_hull(0)
      print(point)
      tracer = pya.NetTracer()
      tracer.trace(tech, ly, ly.top_cell(), pya.Point(point.x, point.y), shape.layer)
      names = set()
      for element in tracer.each_element():
        if element.shape().text:
          names.add(element.shape().text.string)
      pya.QMessageBox.information(None, "Net names", "Net name: %s\nAll names on net: %s" %(tracer.name(), names))
  • Hi,
    yes, exactly this is the right way to do it :-)
    I did not know about "next(...)". Thanks for this sample. This looks pretty useful.
