Lately, I've been playing around with the xsection script and at first glance it seems to do just what I would like. Unfortunately, there seems to be a limitation regarding the maximum height of a cross section. Attached you can see a screenshot of what's going on. The top vias should extend much further and should be covered with another metal layer.
Any idea what's going on here?
I found that the problem is with line 1004-1008 of the xsection script. Unfortunately, I can't adjust the script itself, since it's part of a package. Adjusting these lines to below fixed the problem:
you can set these values inside your .xs script using "height(15.0)" etc. Please see https://klayoutmatthias.github.io/xsection/DocReference for the respective functions.
Thank you once more, that is a better solution of course!
