CREATE AN ARRAY
I'm trying to create a new cell inserting an instance as array 2X2 of my cell.
But the layout imported is only 1X1 of my cell.
Where is the error??
  • I have understand the problem.
    I needed to insert the stepping in X and Y direction compiling the fields
    "ROW VECTOR -----> X"
    "COLUMN VECTOR -----> Y"
    Ciao
    Luciano
  • Right :-)
    GDS basically allows these vectors to by any vectors, so you can create "sheared" arrays too.
    However, some (legacy) systems are constrained to ROW and COLUMN being real row and columns when they import GDS. Cadence used to be such a case. So to stay on the safe side, the x step should go into the x component of COLUMN and the y step should go into the y component of ROW.
