Python code equivalent of converting all cells to static
edited October 30 in Python scripting
I am currently using the following code piece to convert all cells in a layout to static but it seems like it does not work properly. Do you think I am making a mistake in somewhere? I am trying to get the same effect as when I click Edit->Layout->Convert All Cells to Static.
Here is the code I use:
layout.convert_cell_to_static(cell.cell_index())
  • Hello,
    The "convert_cell_to_static" method does not replace the cell - it will rather create a new, equivalent one. In order to replace all cells, you have first to create the static versions, then translate the instances and finally delete the original PCell variants:
    <br />ly = pya.CellView.active().layout()
    cells_converted = {}
    # convert the cells
    for cell in ly.each_cell():
      ci_org = cell.cell_index()
      ci = ly.convert_cell_to_static(ci_org)
      if ci != ci_org:
        cells_converted[ci_org] = ci
    # translate the instances
      for inst in cell.each_inst():
        if inst.cell_index in cells_converted:
          inst.cell_index = cells_converted[inst.cell_index]
    # delete the PCells
    for ci in cells_converted:
      ly.delete_cell(ci)
  • Thank you Matthias!
