Make a circle array
I'd like to know if there is a way to make circle arrays?
For example, I make a cell and draw a small square 10nm x 10nm, and I want to make a circle array in radius 1 mm with this square, if it is possible?
Thank you very much in advance.
  • Hi,
    That's kind of a challenge because you would create 100000x100000 (10^10) squares. So flat shape generation rules out. GDS does not support anything except matrix arrays, so you cannot just draw it.
    I tried the Fill utility which errors out with bad alloc (memory overflow). So finally there is only analytic generation of these arrays through an algorithm.
