pCell not drawn using scripting
spispi
edited March 23 in Ruby Scripting
Dear all
While creating a pCell "CIRCLE" it will add it to the top cell, but showing radius of "0". Only after selecting it, opening the properties and close it by 'ok' it will draw the actual layer and setting the radius correctly.
This prevents me to use the pCell for example in scripts, where they will maintain the radius "0" although I've set a real value.
Is there a way to activate the radius somehow?
Thank you very much,
Martin
ly = pya.Application.instance().main_window().current_view().active_cellview().layout()
ly.dbu = 0.001
layer1 = pya.LayerInfo(1,0)
pCell1 = ly.create_cell("CIRCLE", "Basic", { "radius": 30, "layer": layer1 } )
testCell = ly.create_cell('testCell')
t = pya.Trans(0, 0)
testCell.insert(pya.CellInstArray(pCell1.cell_index(), t))
  • edited March 24
    Hi Martin,
    the actual radius is called "actual_radius". "radius" is what you enter in the text box. As there is also the handle to manipulate the radius, both inputs are consolidated into "actual_radius". This is the value that controls the radius of the circle drawn.
    To make things perfect, you could also set "radius" to the same value and you could also configure a handle by setting the "handle" parameter to a pya.DPoint object indicating the handle position as one point on the circle, like (x_center - radius, y_center).
  • Hi Matthias
    Thank you very much for the prompt response. I very much appreciate your help.
    It did perfectly solve my issue.
    dp = pya.DPoint(x_center - radius, y_center)
    pCellName = ly.create_cell("CIRCLE", "Basic", { "actual_radius": radius, "radius": radius, "handle": dp, "layer": pya.LayerInfo(2,1) } )
    Martin
