Hello Matthias,
I use quite extensive your klayout python module (thanks for that great work). For some tasks the user require to see updates of the Design. Right now I use always start klayout GUI to do so. I wonder on how I could realize best a kind of live preview in QT.
I experimented with your nice example:
from klayout.QtCore import *
from klayout.QtGui import *
from klayout.QtWidgets import *
from klayout.lay import *
app = QApplication([ "reticle" ])
w = LayoutView()
w.load_layout("pcm.gds", False)
w.max_hier()
w.show()
app.exec_()
w = None
Target is to replace the drawing in the GUI with a kind of Mini-Klayout view.
How would you start realizing it?
Andy
Hi Andy,
in the current version, the LayoutView cannot be used as a standalone widget. It's too rightly coupled with MainWindow.
However, this will become possible in the next major release. In this release, LayoutView is a widget that can be used stand alone pretty similar to the way you propose. I've finished the necessary code refactoring, but it's far from being in a good shape.
You can try the master branch on GitHub if you need to. You can also pull a regular build from here: https://www.klayout.org/downloads/master/. But beware that your script will finally only run on future versions.
Thanks for your feedback Matthias,
I'll try the code from github.
I build a complete Mask Generation and WaferMap tool out of all pre-releases you published of the standalone python module and it works fantastic.
Best Regards,
Andy
