Is there something special I need to do to see regions imported from DEF? I have the check box clocked to bring them in to layer REGIONS, and something like the the sample region in the DEF file below, but I don't see the REGIONS layer show up in the Layers list, or a box in the layout.
REGIONS 1 ;
Thanks in advance,
Bret
Hi Bret,
regions are basically supported. Like this (Syntax highlighting fails here, so please ignor colors):
REGIONS are written to a special layer you can specify in the reader options (File/Reader Options, LEF/DEF tab):
Make sure, the Regions checkbox is enabled.
Please note that LEF/DEF is currently undergoing some refactoring. This is not my favourite format, so support is rather weak so far.
