Hi All,
When I ran XOR and no .lyp file, klayout shows me @1 and @2 postfix on the layers to differentiate between Layout1 and Layout2.
I do not see the same when I have layers file loaded. Is there a workaround to see the layers with @1 and @2 foreach source layout?
Here is the properties section of my lyp file.
Best Regards
Rambir
#268c6b
#228c6b
0
0
C63
true
true
false
1
false
false
0
M1.drawing - 1/0
Hi Rambir,
the .lyp file does not show up properly - you should use mark down code formatting when pasting such code (use a line with triple backticks before and after the code).
There is a secret feature which allows embedding dynamic information inside the name. This will add the "@x" layout index:
Explanation:
There are more variables available:
If you don't want to modify the layer properties file you can also use "Regroup/By Layout Index" from the layer list's context menu. This will give you separate trees for "@1" and "@2".
Thank you very much for this one.. Everything you do helps a lot.
Is it possible to have this feature automatic while converting from CDNS techfile to lyp? We can also change it by a postscript i understand..?
wish you a wonderful day ahead.
Thanks & regards
rambir
Thank you again, I could change it in the import_tf routine and it worked very well as well.
Best Regards
rambir
