Undefined method "cell_index" in doing Cell Array
edited June 12 in KLayout Support
Hi, Matthias,
I am a new user for KLayout. I try to generate a cell array and refered to the previous discussion "Creating an array with rotation". However, I meet a problem of "undefined method 'cell_index' for nil:NilClass". Could you help me to check where is my problem?
Belowing is my code:
module MyMacro
  include RBA
#view = Application::instance.main_window.current_view
view = RBA::LayoutView::current
ly = RBA::CellView::active.layout
cell = RBA::CellView::active.cell
## cell array
cell_to_place = "TOP"
radius = 100                       # radius in µm
num = 32                           # number of cells
center = RBA::DVector::new(0, 0)   # circle center in µm
# view = RBA::LayoutView::current
#begin
  # Undo/redo support
#  view.transaction("Create ring of cells")
#  ly = RBA::CellView::active.layout
#  cell = RBA::CellView::active.cell
#  cp = ly.cell(cell_to_place)
  cp = ly.cell("TOP")
 puts cell.class
#  cp || raise("Not a valid cell name: " + cell_to_place)
#  cp_index = cp.cell_index
#  cp_index = ly.cell("TOP").cell_index
  num.times do |i|
    a = i.to_f * Math::PI * 2 / num.to_f
    a_degree = i.to_f * 360.0 / num.to_f
    pos = RBA::DVector::new(radius * Math::sin(a), radius * Math::cos(a)) + center
   trans = RBA::DCplxTrans::new(1.0, -a_degree, false, pos)
   inst = RBA::DCellInstArray::new(ly.cell("TOP").cell_index, trans)
   cell.insert(inst)
#ensure
#  view.commit
#end
outFile = "C:/Users/Desktop/api_layout.gds"
layout.write(outFile)
Thanks a lot!
Candy
  • Hi,
    Looks like "TOP" isn't a valid cell name.
    In this case ly.cell("TOP") will return nil. Hence the error.
  • Dear Matthias,
    Thanks a lot for the comments. The problem is solved.
    I found that, to define a cell, there should not be space on both sides of "=". For example:
    cp=ly.cell("TOP")
    puts cp.class
    ## The out put is "RBA::Cell"
    rather than
    cp = ly.cell("TOP")
    puts cp.class
    ## The out put is "RBA::Nil"
    Candy
  • edited June 16
    No, that can't make a difference. There is no such magic built into Ruby.
    It's the presence of a cell called TOP, believe me.
