I have a Python script which generates a layout and some of the cells are placed at 90, 180, and 270 degree rotations.
This code will place the cell at a 270 degree angle:
idx = _0201_BOT_rect10_63x14_567.cell_index()
inst = pya.CellInstArray(idx, pya.Trans(3, False, pya.Point(-2540000, 2040000)))
TOP.insert(inst)
This code will not:
inst = pya.CellInstArray(idx, pya.Trans(270, False, pya.Point(-2540000, 2040000)))
TOP.insert(inst)
What do I need to do to use the angle instead of the constant? I am using 0.26.6 on RHEL7.
Looking at the documentation, I see this signature:
new Trans ptr new (int rot,
bool mirr,
int x,
int y) Creates a transformation using angle and mirror flag and two coordinate values for displacement
Is this only supported in Ruby?
the documentation also says:
So 0 = 0°, 1 = 90°, 2 = 180°, 3 = 270°. Beside "Trans" there is also "CplxTrans" (more specifically "ICplxTrans") which supports any-angle rotations. But those are discouraged in some applications because they lead to off-grid shapes and other nasty effects.
