Output a Large Image File
edited October 2009 in General
Some time ago, we had a need to for a much larger image file of our layout that was provided by the screenshot feature (File -> Screenshot).
At that time, Matthias was kind enough to provide some instruction for how to do this through the Ruby interface, so I thought I'd record that here in case anyone else finds it of value.
Tools -> RBA Console
In the command line along the bottom of the window, enter the following command, then hit Enter.
RBA::Application.instance.main_window.current_view.save_image("D:/x.png",<xpixels>,<ypixels>)
REPLACE <xpixels> and <ypixels> with the size you desire. In our example, we once output a 10,000 by 10,000 pixel image file.
After completed, command line will clear.
  • edited November -1
    Brilliant! Thanks for posting this.
  • JayJay
    edited November -1
    Works well. In the past, I have been able to achieve the same, only by using a custom routine. Another, somewhat pain full solution is to create a virtual session with large display, then open application in full screen and take a snapshot.
    For vnc:
    vncserver -geometry 8000x8000
    Solution here, with klayout is far simpler.
