Hello to everyone,
I have an object similar to the picture I attached. I want to write a DRC code to check if the angle is less than 70 degrees. But I couldn't write a DRC code to check that this angle is less than 70 degrees. How can I write this code? Thank you!
Here is the way I check non-45 degree angles of the GDS layer (15,0) :
You can probably check it using the command :
Laurent
It worked. Thanks for the help.
