Hi everyone,
I have designed a microelectrode array. Is a multilayer pattern and I need to export it into a monocromatic bitmap, .bmp file.
Is that possible, even layer by layer?
Thanks in advice
Hi, Francesco!
See this topic as script example to save particular layer.
LayoutView.save_image_with_options()has parameter for monochrome image.Hi Eugene,
I'm not really confident about programming. I tryed with this
module MyMacro
include RBA
LayoutView.save_image_with_options("MEA60_RoutingCorrected",500,500.0,0,0,true)
where 'MEA60.." is the name of the file
But without success and inside this function I don't see where I can export in .bmp.
Thanks in advice
Hi, Francesco!
See example script linked in my first answer.
LayoutViewis accessed withRBA::Application::instance.main_window.current_view. See also scripting documentation.Hi Francesco,
please try with a name that includes the file type, e.g. "MEA60_RoutingCorrected.bmp".
If that does not work, you can also use ".png". It will be monochrome and I have made some good experience exporting really huge bitmaps (50k x 50k) with monochrome PNG. But the achievable resolution differs on Linux and Windows.
