apparently "Typing" is not avalible
from __future__ import annotations
# some of these types are deprecated: https://www.python.org/dev/peps/pep-0585/
from typing import Protocol, Dict, List, Iterator, Tuple, TypeVar, Optional
T = TypeVar('T')
  • Okay.
    What is available strongly depends in the Python version your KLayout instance comes with. If you want to have a specific version with specific capabilities, you'll need to build KLayout against it.
    Another option is to use the klayout module from PyPI with your favorite Python. If you're happy with the database part it will be sufficient.
  • Matthias
    Thanks for the reply I am currently using Anaconda with python 3.8
    So how exactly do I use the PyPI module with klayout ?
    Regards
    Tracy
  • Please try "pip install klayout".
    You can use "import klayout.db as pya" to get the "pya" namespace. But it will just provide you with the layout manipulation API.
  • Matthias
    Thanks this works for windows do I need too set a path or env variable?
    Tracy
  • Matthias,
    I have gotten this far and would like to load the following modules,
    many thanks for your help
    T = TypeVar('T')
    # Enter your Python code here
    import os
    import sys
    import math
    import typing
    Regards
    Tracy
  • Matthias,
    I have solved the Protocol module issue based on the
    following https://pypi.org/project/typing-extensions/
    1) download https://pypi.org/project/typing-extensions/#files
    https://files.pythonhosted.org/packages/16/06/0f7367eafb692f73158e5c5cbca1aec798cdf78be5167f6415dd4205fa32/typing_extensions-3.7.4.3.tar.gz .
    2) Extract the tar file then change to the directory typing_extensions-3.7.4.3
    find either the src_py2 or src_py3 , depending on python version used in Klayout,
    cd to either src dir
    3) then copy typing_extensions, to C:\Users....\AppData\Roaming\KLayout\lib\python3.7
    I have tested and this works this could be added to Salt but I do not know how
    this opens up all kinds of possibilities .
    Again thanks for providing this great tool
    Regards
    Tracy
    Code as follows based on Klayout 0.26.9
                import os
                import sys
                import math
                import typing
                from typing import  Dict, List, Iterator, Tuple, TypeVar, Optional
                from typing_extensions import Protocol
                T = TypeVar('T')
                 Location = TypeVar('Location')
                         class Graph(Protocol):
                 def neighbors(self, id: Location) -> List[Location]: pass
                 class SimpleGraph:
                         def __init__(self):
                         self.edges: Dict[Location, List[Location]] = {}
                        return self.edges[id]
  • Hi Tracy,
    thanks for sharing this code and the recipe for installing the extension.
  • Matthias
    Anytime to help the user community ,
    We all learn as we go with this great tool.
    Now if I could get EasyGui to work in the same way :)
  • Very good :)
    BTW: in the recent 0.26.10 version, I have included "typing" in the Windows installation.
