hi, I am new to Klayout appreciate it if i can get any help.
I need to get the coordinates of the objects (lower left and upper right) in diffrent layouts. I tried the following code
layout=pya.Layout()
a=pya.LayoutQuery.new("select cell.name, path_trans * cell.bbox, path_trans.disp.x, path_trans.disp.y from instances of ...*")
for q in a.each(layout):
print(q.data())
error - 'module' object has no attribute 'LayoutQuery' (Class exceptions.AttributeError)
trying this gave attribute error
Hi, Bharat!
See this discussion as example.
thanks @EugeneZelenko it helped a lot.
I see the code is some mix of languages. What are you using? Python or Ruby?
hi @Matthias,
I am using python for coding,
I ran the following code -
iter = layout.begin_shapes(C,c)
while not iter.at_end():
print(iter.shape().bbox())
print(iter.shape().is_polygon(),iter.shape().polygon.transformed(iter.trans()).to_s())
print(iter.cell().name)
if iter.shape().is_polygon():
polygon = iter.shape().polygon.transformed(iter.trans())
print("In cell " + iter.cell().name + ": " + polygon.to_s())
Would you mind formatting the code properly? There is a "code" paragraph style in the editor for the comment. This is not readable, in particular not for Python.
And what's the message? Do you see an error? Unexpected results?
