In my quest to bring a mouse function,
that's easy to use and allow's global
storage of mouse clicks .
I need testers and idea's .
Please feel free to upgrade and comment.
Below are 3 scripts and test script
Save each of the 3 script's individually below into C:/Users/your_path/KLayout/pymacros
update in each script to your system path
ie:sys.path.append("C:/Users/your_path/KLayout/pymacros")
Mouse_XY.py gets the mouse clicks
Subfile.py stores the mouse click in a Global Buffer
Settings.py is the Global Buffer
MouseTest.py
Is the test script
# Copy below and save into "C:/Users/your_path/KLayout/pymacros" as Mouse_XY.py
#Tracy Groller
#3/16/2021
#Get Mouse XY
#Save into a Global Buffer for
#later processing with Settings and Subfile
import sys
#Import Global
#Update to your path
import Settings
import Subfile
Settings.init()
class GetXYOnMouseClickPluginFactory(pya.PluginFactory):
def __init__(self):
super(GetXYOnMouseClickPluginFactory, self).__init__()
pya.MainWindow.instance() # (workaround for bug 191)
self.register(-1000, "mouse_xy", "Get X/Y")
#Turns off add on to Toolbar reset to visible = True too see the tool bar
pya.MainWindow.instance().menu().action("@toolbar.mouse_xy").visible = False
def create_plugin(self, manager, root, view):
return GetXYOnMouseClickPlugin()
# Keeps the singleton instance
instance = None
# Create and store the singleton instance
GetXYOnMouseClickPluginFactory.instance = GetXYOnMouseClickPluginFactory()
# Second thing is the actual plugin
class GetXYOnMouseClickPlugin(pya.Plugin):
def __init__(self):
super(GetXYOnMouseClickPlugin, self).__init__()
pass
def activated(self):
pya.MainWindow.instance().message("Click on point to Get X/Y", 10000)
def deactivated(self):
pya.MainWindow.instance().message("", 0)
def mouse_click_event(self, p, buttons, prio):
# This is where everything happens
if buttons == pya.ButtonState.RightButton :
#Right Click ends it process X/Y coords entered
self.ungrab_mouse()
pya.MainWindow.instance().cancel()
pya.MainWindow.instance().menu().action("@toolbar.select").trigger()
if prio:
#print("Mouse clicked at X/Y" + str(p))
pya.MainWindow.instance().message("Mouse Clicked at X/Y = " + str(p), 10000)
x = p.x
y = p.y
#Add points to global buffer
Subfile.stuff(x,y)
return True
return False
# Copy below and save into "C:/Users/your_path/KLayout/pymacros" as Subfile.py
import sys
import Settings
def stuff(x,y):
Settings.myList.append([x,y])
# Copy below and save into "C:/Users/your_path/KLayout/pymacros" as Settings.py
#Global vars settings
# settings.py
def init():
global myList
myList = []
# MouseTest main Python Test Script
# The mouse click's are saved as a buffer within Settings.myList as a list
# Which then can be processed further within this test script.
import sys
#Import Global
import Settings
import Subfile
import Mouse_XY
#Get Mouse Input
pya.MainWindow.instance().menu().action("@toolbar.mouse_xy").trigger()
print("Mouse X/Y Buffer:", Settings.myList)
Settings.init()
Settings.mylist = []
print("Reset Mouse X/Y Buffer:", Settings.myList)
