I want to use the filling tool in my Python script and for that, I need to translate the following script from Ruby to Python. I have problem with the While loop. Any suggestions?
r = ... # region to fill c = ... # cell in which to produce the fill cells fc_index = ... # fill cell index fc_box = ... # fill cell footprint fill_margin = RBA::Point::new(0, 0) # x/y distance between tile cells with different origin # Iteration: fill a region and fill the remaining parts as long as there is anything left. # Polygons not worth being considered further are dropped (last argument is nil). while !r.is_empty? c.fill_region(r, fc_index, fc_box, nil, r, fill_margin, nil) end
Hi, Mo!
I think
while not r.is_empty()is correct translation to Python. Similar to other methods with question mark.@EugeneZelenko
Many thanks for your help. That solved the while issue but for some reason still the filling does not work!!
fc_box = pya.DBox(...) # fill cell footprint fill_margin = pya.DPoint(self.channel_pitch, 0) # x/y distance between tile cells with different origin region = pya.Region(box8(self.metalrf)) # Iteration: fill a region and fill the remaining parts as long as there is anything left. # Polygons not worth being considered further are dropped (last argument is nil). while not region.is_empty(): fillshape = self.cell.fill_region(region, circle, fc_box, False, amcp_cell_4, fill_margin, False) self.cell.shapes(self.metalrf_layer).insert(fillshape)Isn't
NonePython equivalent ofnil?@MoBe @EugeneZelenko is right. You should use "None" instead of "False".
But there are more issues:
Make sure that "circle" is a cell index. "amcp_cell_4" needs to be a Region and will receive the remaining parts.
Thanks very much for your support @Matthias @EugeneZelenko
@Matthias I understood the first point you made. But I still don't understand how I can fix the while loop so that it will terminate and how I should define "circle" in a way that I can correctly call it on the "fill_region" function. Here is how I defined it.
n = 200 # number of points r = self.channel_radius*1000 # radius da = 2 * math.pi / n pts = [] for i in range(0, n): pts.append(pya.Point.from_dpoint(pya.DPoint(r * math.cos(i * da), r * math.sin(i * da)))) circle = pya.Polygon(pts) self.cell.shapes(self.metalrf_layer).insert(circle)Thank you again for the amazing support here.
MoBe
I think this is what you after ..
I don't know what your channel_radius is
so just plugged in a number
Tracy
@tagger5896 Thanks for the codes. I already defined the circle and it works as it is supposed to. However, the problem is I don't understand in the above scripts, how I should call the circle in the "fill_region" function correctly and how I can stop the loop. Basically, I don't understand the "unsigned int fill_cell_index" written in the documentation for fill_region:
Another point is what I am trying to build is a PCell, and I don't want to make another cell within my PCell (I am not sure if that is even possible). So, basically, I should make the circle within the Pcell and call it in fill_region function. Hope this makes sense!
Thanks again.
The fill_cell_index is the
(you can even instantiate other PCells within a PCell, although I had to bother Matthias a long time until I understood how to do that ^^).
cell.cell_index()wherecellis thepya.Cellobject you want to use for filling. And of course it is possible to instantiate other cells within a PCell, where would the fun be without that possibility@sebastian Thank you for your help. Really appreciate it. However, nothing worked for me to translate the following into python codes, although I was able to do it some other way it is extremely slow because of the loops that it contained! If anyone has an idea, that would be much appreciated!
Hello @MoBe
You should specify the starting point (instead of nil) to make the fill_region work correctly:
The last argument could be set to 'None'.
