Common klayoutrc file
@Matthias Hello!
We have been using your klayout tool in our company for many years.
Long time ago (at version 0.23) I created common place for technology data and common tuned klayoutrc file in order for everyone to have the same settings, and technology definitions. And we run it like "klayout -c $KLAYOUT_BASE_PATH/klayoutrc".
This common place was read only for all files inside for all users.
Recently I have updated klayout up to 0.27.2 version.
After running klayout in same manner (with common and read only klayoutrc file), I'm getting the following warning on exit:
"Warning: Could not create backup file: unable to rename original file '/klayoutrc' to backup file"
But amaizing issue is that klayout changes this read only klayoutrc file!
For example, it writes paths to recently used files and technology in it.
I have no root privileges! How can this happen?!
  • @stolbikov The magic of Unix :)
    Well the explanation is that Klayout keeps backups now - which was requested by some users who lost their work due to network issues while saving.
    So what KLayout does is: when you save something, the existing file is first renamed and then the new data is written. KLayout keeps a specified number of backups, so you can disable backups entirely if you set this count to 0 like here:
    Back to the original question: as KLayout renames the original file but does not touch it, it can do so even if the file is not writeable. In fact the file isn't changed - it's moved. To prevent that you can simple take away write permissions on the directory you keep the configurations in. That will prevent KLayout from renaming the file or creating new ones.
  • @Matthias, thank you for reply!
    klayoutrc file is not moved! KLayout is not enable to rename it and it returns the corresponding warning:
    And KLayout namely somehow touch klayoutrc file and overwrites (or maybe re-creates) it.
    And there are no write permissions of the directory where klayoutrc file is located an all files in it:
    dr-xr-xr-x 5 stolbikov memcom_tools 7 Aug 9 14:33 KLayout/
    KLayout/$ ls -l
    total 118
    dr-xr-xr-x 2 stolbikov memcom_tools 2 Oct 2 2015 drc/
    dr-xr-xr-x 9 stolbikov memcom_tools 10 Apr 29 17:12 klayout_lypgen/
    -r--r--r-- 1 stolbikov memcom_tools 133044 Aug 17 16:22 klayoutrc
    -r--r--r-- 1 stolbikov memcom_tools 132859 Aug 13 17:50 klayoutrc_initial
    dr-xr-xr-x 11 stolbikov memcom_tools 11 Aug 9 11:29 tech/
  • edited August 23
    @stolbikov Why is the path in the error message starting with a slash ("/klayoutrc")? You say you're calling with "klayout -c $KLAYOUT_BASE_PATH/klayoutrc" ... so maybe "$KLAYOUT_PATH_PATH" isn't set?
    Basically no user-space tool can change a read-only directory. So the explanation must be something else.
  • @Matthias
    There is really full path to klayoutrc in the warning:
    "Warning: Could not create backup file: unable to rename original file '/proj/memcom/memcom_tools/KLayout/klayoutrc' to backup file"
    And KLAYOUT_BASE_PATH variable set correctly. Otherwise the klayoutrc file would not have been found, implemented and overwritten.
    klayout binary is installed in /bin/klayout by root.
  • @stolbikov I have only one explanation left: maybe /bin/klayout has the SUID bit set (for an explanation see here: https://linuxhandbook.com/suid-sgid-sticky-bit/).
    If that's the case, this would explain why KLayout can modify a read-only directory, but the bit should be removed immediately. That would be a security hole the size of a barn door.
