How can I reach the above result?
The "inner holes" are the holes that contain no any other hole inside.
My KLayout version is 25.0.5
L1 = input(1,0)
L2 = L1.holes
L2.output(2,0)
L3 = L1.select{|polygon|
polygon.holes <= 1
}.holes
L3.output(3,0)
$tmp = L1
while not ($tmp.holes & L1).holes.is_empty?
$tmp = $tmp.holes & L1
L4 = $tmp.holes
L4.output(4,0)
L5 = L1.holes.select_not_overlapping(L1 - L1.select{|polygon| polygon.is_box?})
L5.output(5,0)
But L2, L3, L4 cannot reach the result I want.
I think I need exclude the L1 with no holes.
So, I come up with L5, but why it fail?
Is there any short Boolean operation could find all inner holes?
@intervalrain That's an interesting challenge
There is no short boolean operation which does that. But I think this operation should do the job:
Thank you, Matthias.
In Version 0.25.5,
I could reach the result with
`L1 = input(1,0)
l1wh = L1.select{|polygon|polygon.holes==1}
l1wh.output(2,0)
inner_holes = (L1.holes-l1wh).select{|polygon|polygon.holes==0}
inner_holes.output(3,0)`
which is referring to your answer.
That's right. This is the equivalent code. But it's slower because the loop is going to be executed in the slow script interpreter.
BTW: why the old KLayout version?
I have noticed that the "(1, nil)" argument to "with(out)_holes" is redundant and not intuitive, so for 0.27.4 I will introduce a parameterless version of "with_holes" and "without_holes" which makes the expression even shorter:
I do have a few more remarks:
