I am using Klayout 25.9, I want to put in vias with specific pitch. How do I put entry on Fill cell margin field?
I tried (1,0) , my vias are filled inside the polygon without space apart. Please advise
In your case, the "v1" cell should contain your via on layer 1/0, and a square on layer 2/0 (boundary layer). The layer 2/0 square defines the via pitch so it should be larger than your via size. The "Fill Cell margin" field can be left blank. It is only needed for enhanced filling.
Thanks tomas2004
