How can I adjust the cell origin using the Python API? I couldn't find any method in the Cell class documentation taking care of this.
In the GUI, it is done using Edit/Cell/Adjust Origin (see the screenshot below):
Hello Rima,
I use the following procedure inside Klayout:
layout = pya.Application.instance().main_window().current_view().active_cellview().layout()
def adjustOrigin(layoutB,topcell):
bbox= topcell.bbox()
trans = pya.Trans.new(-bbox.center()) # center point
# trans = db.Trans(db.Point((-bbox.left), (-bbox.bottom))) #Lower Left Corner
for inst in layoutB.top_cell().each_inst():
layoutB.top_cell().transform(inst,trans)
for li in layoutB.layer_indices():
for shape in layoutB.top_cell().each_shape(li):
layoutB.top_cell().shapes(li).transform(shape,trans)
layoutB.update()
return(layoutB)
layout = adjustOrigin(layout,layout.top_cell())
Hello Rima,
@andyL Thanks for sharing your code
Since 0.26.7, KLayout has a method which should simplify that code:
should do the job of the instance and shape loops.
Great! Thank you very much for your answers!
