Hi, Matthias!
I had script that does some layout processing in batch mode. It's run fine in hidden views mode: klayout <layout> -z -r <script>
, but failed in headless mode: klayout <layout> -zz -r <script>
In both cases layout is accessed trough:
cell_view = pya.CellView.active() layout = cell_view.layout() ... layout post-processing
I added debug prints for cell_view
and layout
and script returns None
for layout in headless mode.
Layout
class documentation is too brief for headless mode, so it'll be good idea to expand it to use cases similar to above. If headless mode doesn't not create GUI objects, may be Layout
class should provide access to collection of opened layouts instead of CellView
@EugeneZelenko In headless mode there is no user interface, hence there are not UI-related objects like MainWindow and LayoutView.
On Linux I solve the problem by running klayout in a virtual XServer environment using
For the future I am preparing a Qt-less release which also features a stripped-down version of
LayoutView
for Python modules. This is not the same as headless mode, but this is a way to batch layout view features without needing a display or even Qt. See here for details: https://github.com/KLayout/klayout/issues/1082Matthias
Hi, Matthias!
Thank you for explanations!
