netlist command in DRC run is very slow and single threaded
Hi @Matthias ,
I'm building this rule deck that uses the connectivity spacing checks solution that you have provided. I'm facing a problem with the speed of the "netlist" command in the DRC context on large layout.
Not sure if there is a way to make the netlist command multi-threaded. Please keep in mind that there is no devices in the DRC run.
Amro
