Chamfer function for fun
Some EDA tool has chamfer function, which can add extra pattern to prevent
metal trace from transition with 90 degree angle or less ( Maybe not often to see in VLSI ?)
Someone told me, it can be done by " round corner " function, but I tried and failed, due to
triangle compensation is preferred.. Share below code for fun, any smart method or comment will be appreciated.
BTW, the initial length of chamfer ( tear_drop ) is 20 " um "
cellview = pya.CellView.active()
layout = cellview.layout()
top = cellview.cell
metal = layout.layer(9 , 0)
tear_drop = layout.layer(6 , 0)
pya.Application.instance().main_window().current_view().add_missing_layers()
target_90 = pya.Region( layout.top_cell().begin_shapes_rec(metal)).with_angle(270, 360 , False)
count_90 = target_90.size()
first_edge_iter_90 = target_90.first_edges().each()
second_edge_iter_90 = target_90.second_edges().each()
target_90_pairs_set = [ k for k in target_90.each() ]
center_90_set = []
start_point_set = []
end_point_set = []
def center_90():
    for i in range(0, count_90):
        center = target_90_pairs_set[i].first.crossing_point(target_90_pairs_set[i].second)
        center_90_set.append(center)
def start_point():
    for j in range(0, count_90):
        P1 = target_90_pairs_set[j].first.d().x
        P2 = target_90_pairs_set[j].first.d().y
        P3 = target_90_pairs_set[j].first.length()
        P4 = center_90_set[j].x
        P5 = center_90_set[j].y
        length = 20000
        if P1 >= 0 and P2 == 0 and P3 >= length:
            start_point_set.append(pya.Point(P4 - length, P5))
        elif P1 >= 0 and P2 == 0 and P3 < length:
            start_point_set.append(pya.Point(P4 - P3, P5))
        elif P1 < 0 and P2 == 0 and P3 >= length:
            start_point_set.append(pya.Point(P4 + length, P5))
        elif P1 < 0 and P2 == 0 and P3 < length:
            start_point_set.append(pya.Point(P4 + P3, P5))
        elif P1 == 0 and P2 >= 0 and P3 >= length:
           start_point_set.append(pya.Point(P4 , P5 -length))
        elif P1 == 0 and P2 >= 0 and P3 < length:
           start_point_set.append(pya.Point(P4 , P5 - P3))
        elif P1 == 0 and P2 < 0 and P3 >= length:
           start_point_set.append(pya.Point(P4 , P5 + length))
        elif P1 == 0 and P2 < 0 and P3 < length:
           start_point_set.append(pya.Point(P4 , P5 + P3))
        else:
           pass
def end_point():
        P1 = target_90_pairs_set[j].second.d().x
        P2 = target_90_pairs_set[j].second.d().y
        P3 = target_90_pairs_set[j].second.length()
        length = 20000
            end_point_set.append(pya.Point(P4 + length, P5))
            end_point_set.append(pya.Point(P4 + P3, P5))
            end_point_set.append(pya.Point(P4 - length, P5))
            end_point_set.append(pya.Point(P4 - P3, P5))
            end_point_set.append(pya.Point(P4 , P5 + length))
            end_point_set.append(pya.Point(P4 , P5 + P3))
            end_point_set.append(pya.Point(P4 , P5 - length))
            end_point_set.append(pya.Point(P4 , P5 - P3))
        else:
           pass
def tear():
    for x in range(0, count_90):
        P1 = start_point_set[x]
        P2 = center_90_set[x]
        P3 = end_point_set[x]
        poly = pya.Polygon( [ P1, P2, P3 ] )
        top.shapes(tear_drop).insert(poly)
center_90()
start_point()
end_point()
tear()
  • edited July 15
    Now you are challenging me :)
    Here is a simple solution that uses a DRC function with an intra-polygon space check with an above-90 angle limit to generate notch violation markers on inner 90 degree-corners. 1µm is the edge length of the marker:
    original = input(...)
    patches = original.notch(1.um, angle_limit(91.0))
    (original + patches.polygons).output(...)
    Result:
    This approach will not work properly on edges less than 1µm length because then the chamfering gets non-45 degree.
    The rounded-corner approach works as well (DRC) when you set the outer corner radius to 0 and use the octagon approximation (n=8):
    f = 1.0 + Math::sqrt(0.5)
    original.rounded_corners(f * 1.um, 0.um, 8).output(...)
    Caveat: the corner rounding does not apply full radius on edges shorter than f µm (f is 1.707...) but applies a smaller chamfering:
    So both approaches have a slight disadvantage that you may be able to mitigate with specific design rules.
  • hello Matthias,
    You should be kidding me.. :)
    Method one already works perfectly to me, I have no ruby background, so I missed many great information in the manual, even can not understand properly.You solution always hit the problem in 3 rows, it is magic.
    I am not sure why I can not upload a gds file on.. so please see below image:
    the solution also can make the tear for a trace connect to circle, it's already good enough to tape out mask if merged polygons, even better than what Cadence did, but I will keep trying to make it as " triangle " shape to reduce file size if convert to MEBES. Maybe will share another long code again, when it's done :D
  • Very good, thanks for the feedback :)
    You can upload GDS if you zip it. This forum does now know about our favourite file formats ...
  • edited July 17
    Hello Matthias,
    It's my bad, I should notice that, updated test gds ok, and trying to solve it with math.(sin , cos, tan) friends..
  • edited July 18
    Hello Matthias,
    Try & error, come out below code, it seems work,
    Thanks for your perfect reply and this creative tool :)
    Vincent
    from pya import *
    import math
    top = cellview.cell
    bump = layout.layer(6 , 0)
    tear_drop = layout.layer(5,0)
    tear_length = 30000
    pillar = pya.Region(top.begin_shapes_rec(bump))
    metal_poly = pya.Region(top.begin_shapes_rec(metal))
    dummy = ( pillar + metal_poly).merged()
    #dummy = ( pillar + (pillar.sized(50000) & metal_poly)).merged()  # use this dummy instead of previous will enhance success rate
    target = dummy.with_angle(181, 359 , False)
    target_pairs = [ k for k in target.each() ]
    for pair in target_pairs:
        if pair.first.length() > pair.second.length():
            P1 = pair.first.p2 + tear_length*(pair.first.p1 - pair.first.p2)/pair.first.length()
            P2 = pair.first.p2
            P3 = pair.second.p1 + tear_length*(pair.second.p2 - pair.second.p1)/pair.second.length()
            pillar_hull_coordinate = []
            pillar_corner_to_p3 = []
            for k in [ k for k in pillar ]:
                for l in range(k.num_points_hull()):
                    pillar_hull_coordinate.append(k.point_hull(l))
                    pillar_corner_to_p3.append(k.point_hull(l).distance(P3))
            for k in pillar_hull_coordinate:
                if k.distance(P3) == min(pillar_corner_to_p3):
                    P3 = k
            tear = pya.Polygon([ P1, P2, P3 ])
            top.shapes(tear_drop).insert(tear)
        else:
            pass
        if pair.first.length() < pair.second.length():
            P2 = pair.first.p2
            pillar_corner_to_p1 = []
                    pillar_corner_to_p1.append(k.point_hull(l).distance(P1))
                if k.distance(P1) == min(pillar_corner_to_p1):
                    P1 = k
  • edited July 20
    Of course this solution is valid too and I really want encourage users to try their own ways. So please go ahead and thanks for sharing the code! :)
    There are a few things you're probably aware of:
    • It's slower because of the Python loop
    • You will see all patches cells on top level of the hierarchy. The DRC-based solutions can be made hierarchy-aware (patches pushed down into the hierarchy) by simply using "deep" mode.
