One of the main features I use in a layout editor/viewer is to search for one (or more) text labels because we use these labels to identify terminals in hierarchical layouts. As far as I know, there is no such function in KLayout yet, please correct me if I'm wrong on that.
Before I heard of KLayout, I was using Glade and still use it if I have to search. The Glade search allows me to search texts or instance names, zoom to the found items and optionally highlight them. It also allows to search using regular expressions or a simpler wildcard search (using * for any character string or ? for any single character). It searches top-level texts only, which is what I need 99% of the time.
Is such a feature planned for KLayout?
Hallo,
such a feature is on my TODO stack, but among many other features of similar nature, so I can't give a time frame.
Basically, it's possible to add such a feature by scripting. There are a couple of examples in this forum and on the "Useful scripts" page, which can be used as a template.
Let me make one general remark here: KLayout, unlike Glade or the commercial alternatives, is open source under GPL. That means, everybody with some programming skills can add features, start his own branch or contribute the code back to me. So for open source projects, a lacking feature is not a gap, it's an opportunity.
Simply paste the text following the dashes into a find_text.lym file and place it into the macros folder, restart KLayout and press Shift+S to open the dialog.
<klayout-macro>
<description>Find Text</description>
<version/>
<prolog/>
<epilog/>
<doc/>
<format>general</format>
<autorun>false</autorun>
<autorun-early>false</autorun-early>
<shortcut>Shift+S</shortcut>
<show-in-menu>true</show-in-menu>
<group-name/>
<menu-path/>
<interpreter>ruby</interpreter>
<text>module FindTextMacro
def FindTextMacro::match(test, all)
matches = []
starts = []
mids = []
others = []
all.each do |k, v|
if k == test
matches << [k,v]
elsif k.start_with?(test)
starts << [k,v]
elsif k.include?(test)
mids << [k,v]
else
others << [k,v]
if matches.length > 0 or starts.length > 0
level = 2
elsif mids.length > 0
level = 1
else
level = 0
return level, matches.sort + starts.sort + mids.sort + others.sort
include RBA
require 'ostruct'
def FindTextMacro::find_texts(lo, cl, recursion_limit=0, prefixes=[])
texts = {}
lo.layer_indices.each do |layer_idx|
#puts "Layer index: #{layer_idx}"
cl.each_shape(layer_idx) do |shape|
if shape.is_text?
text = shape.text
point = text.trans.trans(Point.new(0,0))
name = (prefixes + [text.string]).join('.')
#texts[name] = point
texts[name] = OpenStruct.new(:point=>point, :layer_index=>layer_idx)
if recursion_limit > 0
known_cells = []
cl.each_inst do |inst|
child_cell = lo.cell(inst.cell_index)
cell_name = child_cell.basic_name
if not known_cells.include?(cell_name)
puts "Descending into cell #{cell_name}"
child_texts = find_texts(lo, child_cell, recursion_limit - 1, prefixes + [cell_name])
puts "Finished cell #{cell_name}"
#texts.merge!(child_texts)
child_texts.each do |name, point|
#texts[name] = inst.trans.trans(child_texts[name])
texts[name] = OpenStruct.new(:point=>inst.trans.trans(child_texts[name].point), :layer_index=>child_texts[name].layer_index)
known_cells << cell_name
return texts
app = Application.instance
mw = app.main_window
lv = mw.current_view
if lv == nil
raise "Find Text: No view selected"
cv = lv.active_cellview
lo = cv.layout
cl = cv.cell
texts = find_texts(lo, cl, 1)
dialog = QDialog::new(Application.instance.main_window)
layout = QVBoxLayout::new(dialog)
dialog.setLayout(layout)
edit = QLineEdit.new(dialog)
list = QListWidget.new(dialog)
layout.addWidget(edit)
layout.addWidget(list)
depth_label = QLabel.new("Max. hierarchy depth: ", dialog)
depth_edit = QLineEdit.new(dialog)
depth_edit.alignment = 2 # Qt::AlignRight
depth_edit.text = "1"
depth_layout = QFormLayout::new(dialog)
depth_layout.addRow(depth_label, depth_edit)
layout.addLayout(depth_layout)
def FindTextMacro::refresh_list(list, edit, texts, dialog)
dialog.windowTitle = "Find Text (#{texts.length} labels found)"
list.clear
level, matches = match(edit.text, texts)
if level == 0
edit.setStyleSheet("background-color: #FAA");
elsif level == 1
edit.setStyleSheet("background-color: #FF8");
else
edit.setStyleSheet("background-color: #AFA");
matches.each do |text, data|
#list.addItem "#{text} (#{data})"
#layer_name = lo.get_info(data.layer_index).name
list.addItem "#{text} (#{data.point}) #{data.layer_index}"
depth_edit.textEdited do
#puts depth_edit.text
texts = find_texts(lo, cl, depth_edit.text.to_i)
edit.textEdited do
#puts edit.text
def FindTextMacro::pan_to_list_selection(list, lo, lv)
if list.selectedItems().length > 0
puts list.selectedItems()[0].text
match = /\((?<x>[\d-]+),(?<y>[\d-]+)\)/.match(list.selectedItems()[0].text)
pan_pos = DPoint.new(match[:x].to_f * lo.dbu, match[:y].to_f * lo.dbu)
lv.pan_center(pan_pos)
list.itemSelectionChanged do
list.itemClicked do
texts.sort.each do |text, data|
dialog.show
end</text>
</klayout-macro>
Hi friendx,
that's not too bad :-)
Regarding the performance, it may help a lot to use the RecursiveShapeIterator object which is delivered by Layout#begin_shapes.
The loop then may look like this
