Get shapes from all subcells of cell
edited September 2022 in Python scripting
Hi -- I would like to pull all shapes on a given layer of a cell.
When the cell has no subcells, this works easily.
SourceShapes = ParentCell.Shapes(SourceLayer)
However, say ParentCell has no shapes in the top level, but instead instances of ChildCell1, ChildCell2, and ChildCell3. The three child cells all have shapes in SourceLayer, but if I run
in this case then no shapes are returned.
Is there a simple method get all the shapes in all levels of the cell hierarchy within ParentCell?
  • If anyone encounters this themselves, my cumbersome workaround is:
    holder=layout.create_cell("flatcell")
    holder.copy_instances(ParentCell)
    holder.flatten()
    flatshapes=holder.shapes(SourceLayer)
    SourceShapes= flatshapes.dup() #this line seems particularly clumsy but I have not found a way to avoiding needing it
    holder.delete()
  • edited September 2022
    What you are looking for is the `RecursiveShapeIterator`.
    If you purely want a shapes object you can do it with this:
    SourceShapes = pya.Shapes()
    SourceShapes.insert(ParentCell.begin_shapes_rec(SourceLayer))
    What I suspect is what you want is a region in the end. You can directly construct the region from the iterator
    region = pya.Region(ParentCell.begin_shapes_rec(SourceLayer))
    P.S. not sure why code rendering is not working. I will try to fix it when I find out what I did to break it
  • @sebastian Code rendering needs lines with three backticks only. Like this:
    And thanks for the discussion. The RecursiveShapeIterator is the right approach.
    If you want to just read the shapes, you do not need to collect them in a Region object. As the name implies, the RecursiveShapeIterator iterates over the shapes while visiting all child cells in the hierarchy. It is a quite powerful class that has many options - e.g. confining the search to a region or selecting/deselecting certain cell paths in the hierarchy. There is more documentation here: https://www.klayout.de/doc-qt5/code/class_RecursiveShapeIterator.html#k_1
    The Region class is similar to Shapes, but much more powerful. It stores polygons only (or the polygon versions of "polygonizable" objects). It will contain a flat set of polygons derived from the RecursiveShapeIterator. Pulling this expanded set of polygons may be expensive if you have a deep hierarchy with many cell repetitions. More information about the Region class is found here: https://www.klayout.de/doc-qt5/code/class_Region.html
  • Thank you very much! begin_shapes_rec does exactly what I needed.
    @Matthias I am not sure why it didn't work, that's exactly how I wrote it (the first time). Could the problem be that I authored it on mobile?
    Test Code
    In here it works now (from desktop). But I cannot even edit the comment anymore to allow it to use proper markdown :tongue:
    I could fix it for you but then the comment does not make sense :)
    But I also don't see a problem. Some weird encoding issue or "alternative" backticks on mobile browsers? No idea ...
  • I just tried editing to see whether that was the case, but no, even if I replace them in FF on desktop, it doesn't fix it ¯\_(ツ)_/¯
  • Yet another case of magic :)
