This code manages to unselect all selected polygons... but I haven't figured out how to hide them yet:
print('\n\nStarting KLayout Script')
lv = pya.LayoutView.current()
currently_selected_polygons = lv.object_selection # list of ObjectInstPath
if not currently_selected_polygons :
print('no polygons selected in KLayout window')
else:
#print(dir(currently_selected_polygons[0]))
pass
for o in currently_selected_polygons:
if (o.shape.polygon.is_box()):
# currently let us ignore non-box shapes
bb = o.shape.polygon.bbox()
ll, ur = bb.p1, bb.p2
print(f'Selected rect width({(ur.x - ll.x)}, height {(ur.y - ll.y)})')
lv.unselect_object(o)
# lv.select_object(o) # you can also immediately select it again too, just to prove the concept
This code manages to select all shapes on a given layer... I haven't figured out how to show them yet, though (and hide all others):
cv = pya.CellView.active()
layout =pya.CellView.active().layout()
shapes = {}
layer_name_to_layer_index = {}
for layer in lv.each_layer():
l= layout.find_layer(None, None, layer.name)
layer_index = layer.layer_index()
layer_name_to_layer_index[layer.name] = layer_index
# ignore/filter-out some layers based on name
if 'm0' in layer.name and 'drawing' in layer.name:
print(layer.name)
shapes[layer.name] = []
for c in layout.each_cell():
iter = layout.begin_shapes(c, layer_index)
while not iter.at_end():
shapes[layer.name].append(iter.shape())
if iter.shape().is_polygon():
# I never seem to get in here... not sure why, as later on the code DOES successfully select these shapes
polygon = iter.shape().polygon.transformed(iter.trans())
print("In cell " + iter.cell().name + ": " + polygon.to_s())
iter.next()
selections = []
for layer_name in shapes:
print(f'about to select all shapes in layer ({layer_name})')
layer_index = layer_name_to_layer_index[layer_name]
for p in shapes[layer_name]:
selection = pya.ObjectInstPath()
selection.layer = layer_index
selection.cv_index = cv.index()
selection.top = cv.cell_index
selection.shape = p
selections.append(selection)
# make the new shape list become selected
lv.object_selection = selections
If you want to hide entire layer content, you could find layer properties for given layer/datatype iterating LayoutView.begin_layers()/end_layers() and than set LayerProperties.visible to False.
I think LayoutView.each_layer should work for you. I used LayoutView.begin_layers because of more complicated situations like layer properties deletion.
Hi!
and than setLayerProperties.visible
toFalse
.Hi Eugene is
begin_layers
/end_layers
different/better thanfor layer in lv.each_layer():
? The latter feels more Pythonic, which is preferable.Hi!
I think
should work for you. I usedLayoutView.begin_layers
