How to size a layer but only in 1 direction : top or right or bottom or left ?
I guess I have to use the extended_out method because .sized() will extend in both direction top and bottom or left and right.
Maybe extent.refs is a better method ?
Any proposal ?
Thank you, BRgds,
Laurent
My proposal was size and move by half the size amount. At least that is how I would implement it internally
So like:
This simple solution suffers from non reproducing 45 degree edges:
To mitigate this, you can split the size in two steps for x and y:
I'd be careful in general - this will break isotropy and if you intend to do that hierarchically, variant generation will happen.
Thank you Matthias, furthermore I needed to mixed moved and sized functions, it perfectly meets my need, except ... that I cannot resize the result. As in your exemple :
the second line will return an error
I use the very latest version 0.28 of yesterday under Windows-10.
Laurent
Hi @laurent_c
I assume that is deep mode, right?
I think that "original" for some reason has a wrong binding. If "original" comes from "extended", the problem may be related to this bug: https://github.com/KLayout/klayout/issues/1190
I merged it November 25, so maybe you just missed it
Indeed, I was using the deep mode, but with random shapes (polygons, paths, ...). Now, it works fine in tile mode, but not in deep mode
, now, I use the version of December 2.
As usual, I was using your latest version
Laurent
That's bad.
Can you say where "original" comes from? Maybe there are more cases like the "extended" problem - although I don't know of one.
Sorry, stupid me. You're perfectly right. I can easily reproduce the problem
Here is the ticket: https://github.com/KLayout/klayout/issues/1216
I'll fix it asap.
Fixed in master.
"original" for me is the result of place&route of OpenROAD. I am trying to run some check on it, so "original" can be rectangles, polygons or paths from the current level of a hierarchy below.
BRgds,
Laurent
Sorry for the confusion, I had to try myself before understanding the problem.
I have fixed that issue in 0.28 which has been released yesterday.
